drawing quotas from unified components
  • Thread starter Thread starter Aiuto2
Aiuto2
the design asks me to obtain the measurements from the unified components.
is it enough that I echo the size of one of these and do the proportion for all other dimensions not listed or is there another procedure?
a good start is, at the first message, to greet and in order to thank for the attention received.
with the size an object revenues all the rest
You're right. I'm sorry. I'm sorry. So is it enough to get the proportion from a screw and I also echo the bearing housing without browsing all catalogs and standards?
a screw cannot be a precise reference.
What do you mean? only on the diameter measured with the ruler?
a bearing in addition to having well defined measures being larger allows you to reduce the proportion error; do not need to browse catalogs, just write in a search engine the abbreviation and you will have under hand the skf page with its size
So from the size of a bearing I make the proportion and echo all other measures right?
