drawings of assemblies and sub-assiemi.. .
  • Thread starter Thread starter GiGa
GiGa
I would like to say that we are not going to be able to do so. ..axieme of machine composed of body + command group + other particular varivarie tables required:axieme general(under)axieme body(under)axieme group commandothers (under)assiemi minorovviamente would be trivial to put on the table the assemblies and via... but if I wanted to see the other part (or at least one piece of it) in sub-assiemi? I cannot put the general axieme into the table and indicate a part as "referral" because it would also go for all the other assemblies.. .exposing a "heavy" machine, I would like to avoid having to enter it as a reference in the assembly of the command group, and vice versa. especially for not having to open every time the "assiemon" also for sub-assiemes composed of very few parts.excluding creating a simplified part because I have already tried and after several hours of calculation I had to close the conversion.you would like to manage them?
You could make a series of two celebrations, step 0, of the whole axemon.
the first anniversary is the good one, while the second is referred.
On the table, turn on and off the under groups you need.
It seems like a great solution... to evaluate only the pros and cons. for now, cause haste, I had to proceed in another way (conversion of the assieme reported in a single part). As soon as I can, I see if I can change the references of the drawings (not to give them back from scratch) to use your solution...I thank you. . .
