gil
As a result of a lively discussion I would like to ask you this question.
take for example a metal frame with base plate as from drawing, to be fixed to a foundation in c.a. in which bars were preceded for the anchoring of the plate.
what size would you make holes on the plate?
1) hole diameter = fixing bar size + 1 or 2 mm tolerance
2) hole diameter = fixing bar size + 5 or 10 mm to make it possible to compensate for any bar laying tolerances?
