drilling of a sheet
  • Thread starter Thread starter jonny@
jonny@
Hello everyone
I know this is very simple, but I need help from qyalcuno. . .
I designed with autocad, a detail to be made of 1mm sheet, with holes, oram how do I display the holes in 3d, and give a bending radius to the sheet of 45 degrees?
thank you all... !
You say you made 1mm sheet with holes....and now you have to bend it? but a sketch, a hint at the difficulties you encounter!? would make us comfortable to understand the difficulty you encounter!? !
I have already realized my 2d sheet design, with holes and fittings, to be sent to the machine that will cut it to the plasma, but after this processing, the sheet will have to be folded, and I would like to make in 3d, this sheet with a bending radius of 40 degrees... it is possible to do it starting from the drawing in 2d, which represents the perfectly flat sheet. .
40-degree radius?? :eek::rolleyes:
I realize that there is a question at the end, and the answer is: no, change cad.
Okay, bye, jonny. I think I know what you mean and the answer is: "yes you can do." but it's not easy.. Could you attach the dwg file to your message so you can reason? methods to do what you ask are 2.. or with regions (more spartan but unique if you have lt) or with the 3d interface of autocad if you have full.
Many thanks teo, I will divide the sheet into regions, and I will work on it,
I was used to cocreate... .
