Drucker-prager
  • Thread starter Thread starter francesco.pro
francesco.pro
hi to everyone is the first time I write on the forum so I take advantage of it to greet everyone and to thank you in advance for the support you can give me.
I am using ansys workbench for a solid structural modeling dependent on time. all right until I used elastic materials, I then had the need to insert plasticity and in particular the behavior drucker-prager and I noticed that in engineering date I did not appear voice also changing type of analysis. linking another engineering given to my model appeared to me the voice and I inserted it into the material thus keeping the analysis dependent on time. I thought I solved the problem but, performing the analysis, I have no plastic tension and consequently no change compared to the elastic case and therefore without inserting the drucker-prager.
What could be the problem?
Is it normal that without linking another data engineering there was no voice?
with the pressure I put in I should have plastic tensions so it should be a software setup problem.
thanks in advance.
I remind you that the up is not allowed (it is a forum rule).
Probably nobody knows your problem.
but did you try to feel the assistance? generally I do so and respond immediately!
