dubbio fori sw
Dott.Rise
Good morning to all,
I write you because I have a problem with holes but looking here on the forum, I have found nothing that can do to my case.
for my project of year I find myself having to make a threaded connection; we take as example this, in which I have a green square plate (from which to insert the screw) that must be connected to a yellow rectangular plate:
Piastre senza fori.webpduring my studies, I learned that a threaded coupling can be done in two ways:- Case 1: by means of a threaded bolt at the end + nut. this fits into a smooth hole;- Case 2: through a life. and in this case the hole that connects the two plates must be threaded only on the plate that will receive the tip of the screw.If there is any mistake, please correct me already from now.all the holes I will go to realize were made with "guided creation of holes".
in case I have to realize the first case (bullone+vite) I would need to make a smooth hole and I oriented towards the drilling option (the third of the first line available between "hole type") with a size, suppose, m10. the result is exactly what I had in mind, smooth hole in which to insert the bolt that will then be screwed on the bottom with a nut:
Dettaglio foro bullone.webpSuppose now that it should connect with screw (case two). instinctively I oriented to "linear fingering" (the first of the middle row in "hole type"); m10, result:
Dettaglio foro tutto filettato.webpthat is not what I wanted (as only the yellow plate must be threaded).
then I had the idea of making a simple hole m10 as the first case and then manually threading only the yellow plate by means of " cosmetic fingering":
Dettaglio foro filettato.webpand here are the painful notes: first of all because I don't know if this way of acting can be accurate, can anyone confirm?and then because at the moment when I do the mapping of the hole m10, in "dimensions" are present only those from m14 up. Shouldn't I have the option to choose a m10 yet?
Menufilettature.webpEverything makes me confused, is there anyone who can help me? in particular I would like to understand how to actually make a connection by means of a screw, in which only the lower part of the coupling is threaded. :confused:
Thank you in advance.
Are you making holes in the environment together (therefore only function that is propagated to the parts) or environment part (then separate functions, though with shared sketch)?
I'm together, I coupled the faces between the two plates and now I should make the connection
in the environment together you have to use series holes to have the drilling differentiated between one plate and the other
Great! I bring back here the procedure I followed, should serve someone:
it was necessary to prepare the green plate in the environment part to have a guide to the real hole in the environment together. After that (together) choosing set holes I gave as guide the foreskin and then went into the thread option (the fourth). this is the result:
Foro doppio.webpat this point it was possible to connect with screw:
ti ringrazio!
if you holes a plate in the environment part to have a reference to do the function in the environment together is redundant; At that point, always from the axieme, you change part of the other plate and do the threaded hole by putting the concentric point to the other hole.
the holes series serves to do all the procedure with one shot only and all in the environment together (probing or not the function to the parts is optional)
with 3d sketch? Yes, you can also do so
the moment you select series holes, you open the sketch window. on the left, in the tip in yellow, tells you to draw with a sketch or select an existing hole. as soon as I have time I make a screen
do not need to make any sketch 3d. select the starting face and insert the sketch point.
Just one point? without giving a hole axe? I will try because it is so much more convenient
