dwg to pdf da macro
  • Thread starter Thread starter Barone_Birra
Barone_Birra
Good morning to all, I looked for a little but I found nothing very clear, I have a folder with n dwg files I would like from a vba script to save them all automatically in pdf (in the same folder or even better in a new one). the main problem is that I don't have vba included in autocad and can't download it and install it, can you do it from a vba script of excel? I already do this with solid edge draft files, but for autocad I don't know where to go (I almost never used it).
if you refer to simple and non-mechanical autocad the discussion goes open in the autocad section because in this section has little visibility.
However, just a simple script.
in This post find the createscript file that does almost everything automatically; You just need to enter the commands you'd throw in autocad.
For example:
open file
save
pdf
Shut up!
