dxf conversion in step or neutral model
  • Thread starter Thread starter gerod
gerod
I need to convert to 3d a dxf that comes from a calculation program structures (export only to dxf)
I have autocad lt and I see it as three-dimensional lines, only that I can't export it to a format that can open with solid edge.
there is someone who could make me this conversion (I imagine inventor doing it) in a solid edge format (step, x_t, sat, igs).
ps: as the files are big (4 mega, I have two), maybe I send them to you via dropbox.
ps2: I can leave the mail via mp.
Greetings.
but sorry I would not say a stupid thing but also autocad mechanical it does, commands steepin - steepout or something.....
I solved with two of you... So I don't want to leave you too long.
We say the sat is the best.
Thank you all.
Thank you all.
Hello, everyone. .
maybe I have the same problem...I have the two-dimensional dxf file and I would like to convert it to 3d (.stp if possible, but also .sat, .stl) and then have to open it with a cadcam..ma program with autocad 2010 I can't. .
the procedure I follow is this:
1-file->export
2-map extension .stl and/or .sat
3-click on "Save"
4-hour on the slider shows me the word "select the solids or hermetic mesh"
5-At this point I select the design (view 3d)
6-We will send, once again I send and the program does nothing to me.. not exposed the file. .
excuse my "imbranataggine":wink: I ask you it is possible to export ul dxf file in a .sat and/or .stl?
Sorry again. .
