dynamic block attributes extraction problem
  • Thread starter Thread starter Shark79
Shark79
Good morning, guys.
I have a problem with extracting attributes contained in a dynamic block.
my problem arises from the fact that I would like to tie the graphics to the component code (now it is not so)
so I created a test block with the graphics and code that can be moved using dynamic properties.
with the -estratt command and its extraction model I would like to extract the data on txt
attached drawing, extraction pattern and extraction files as it should be.
I should extract the code field (even others but made one...) from the dynamic block.
I ask your help.
