dynamic block curve per channel
  • Thread starter Thread starter STAP
STAP
good day, I've been trying to create an office library for mechanical components such as pipes and channels.
I have the following problem, I have created a curve block from where I can choose whether to use a 30°45°90° curve with various visibility and the possibility to change its size.
I would have a question there is a way to create a curve with fixed or at least adjustable internal radius?
now the curve scales according to the set length and therefore also the internal radius.
to get the various curves with the various corners I have made visibility with various objects inside, is there the possibility to get from a single object a curve that from 90° steps to 30° for example?
allego file
I don't know if I was clear about my intentions
You have already made this request in another discussion. opening another creed I know confusion, also in the forum, which is made of users with professional and personal commitments, you must have patience
hi, on udemy with a few € you can buy and have life access to the course dynamic acad blocks. excellent examples and clear and exhaustive course.
I deleted the post on the other topic.
is there the possibility of obtaining from a single object a curve that from 90° steps to 30° for example?
Yes, but you should play heavily with geometric and dimensional constraints and, in my opinion, it is not worth considering costs/benefits
See if that's what you were asking. is to be completed with restraints and relative visibility states but the base is made
Yes thank you is what I was trying to do but I did not understand how to do with the constraints, now it is clear to me thank you so much.
Now I try to change my block to see if I understand the operation.
