dynamic block with attribute associated with stretching
  • Thread starter Thread starter duken
duken
Good evening,
I hope it has not been dealt with before.
Is there a possibility to associate a text attribute with a stretch?
In the sense if I iron my object the text (attributed) inside the block is updated according to the measure.
alternative would be to insert a quota and resolves but the quota weights the blocks, and mirroring the text remains reversed.
Do you have any advice?
use data fields (_field)
Hi, I took a look. .
I created a rectangle with the text attribute in the center and in the field "default" click on the field icon.
to obtain the upgraded attribute according to the imposed "all" field category stretching, type of object should I select the linear parameter?
Okay thank you.. but I don't understand why it doesn't make me remove the decimals, I have 1800 and he is 1800.00.
I noticed that the precision panel is disabled
