dynamic block with attribute block that remains fixed
saro
Hello
I have a problem with a dynamic block. I use autocad 2012. I created a symbol/boil for the fixtures where I can write the width, height and davanzale. I made sure to convert it into a dynamic block so that the symbol has the ability to stretch according to the thickness of the walls.
1. I put the linear parameter with one grip to stretch in one direction
2. I selected the stretch action: selecting the parameter, then the symbol portion that must stretch and I selected the symbol including the "davanzale" attribute block (i.e. when the line stretches I would like this attached block to follow the stretch)
3. Save
practically the symbol stretches but the "davanzale" attribute block remains firm.
What can I have done wrong?
thanks for the help
At point 2, did you do everything right?
a - select the drag point
b - then define the rectangular endpiece in which the lines fall and in whole the attribute
c - selections objects that need to move, line + attribute.
Moreover, it should not serve, but as a 'extreme' gesture test the sincatt command (_attsync for English version).
(a) b) and c); the attribute block I put it both in "lock position" and not, but already when they select all objects (as mentioned in point c)), in command appears the warning that the attribute block has been filtered by the selection. so if I exit from the editor the line stretches but the block attributes does not move. I also tried in other locations. and yet it is an operation that in the past with other versions of autocad (2007 and 2010) I did without problems.
p.s. what does sincatt need?
Okay perfect, I tested the Atsync, it worked. I have to say, however, this is absurd. If I change the block and save it seems obvious that you should automatically sync, it seems absurd that I should do it manually every time.. .
Anyway thank you 1000.
p.s. but attsync command is not equivalent to synchronization that you do from the attribute block editor window?
attributes are special objects. Although contained in a block they can locally (in an inserted block) undergo changes to their properties (height, position, factor of width, angle of rotation etc...).
every time I redefine a block (close the editor blocks)
it is not said that I always want to update even the attributes contained in it.
if this happens always (default) will 'reset' any local changes made in the various blocks already inserted. that is why further confirmation is necessary - via sincatt - for updating the attributes of the blocks.
I don't know what you mean by 'object block editor window'
inside the block command window attribute manager (in modify>object>attribute) there is the syncronize block command
I understand... the famous _battman. Yes, that synchronization has the same effect as a sincatt.
I finally get it!
Before adding a "set action" to the dynamic block you must remember to put "yes" in the "lock position" parameter in the attributes you want to insert in the block.
otherwise when you do the window excludes them automatically and in the "comand line" read:
select objects: specify opposite corner: 9 found
select objects:
6 unlocked attdefs filtered from selection.
Damn ignorance.
Thank you all for your indirect support.
Staff online
