tecnodoff
Hello, everyone!
v list my "problem":
I created a dynamic block with the plant of an element (a simple rectangle) to which I set parameters "serious" for the two dimensions.
all right here but now I would like to add the section of the object (ke and another dynamic block) and the quota and make in a way ke ironing sl the size of the plant si midifichin to pursue section and internal quota.
I would also like to know if there is a way to be able to bind the quota and the section always in halfway to the plant so as not always to hand over the element.
I hope I've been clear
Thank you all!
Thank you all!
