dynamic insertion
Angelo2449
Hello everyone,
I would like to insert a block, previously created, dynamically or, once defined the insertion point, the block should rotate around it until the click of the direction point, with the drag effect.
how should the "_insert" command be structured to achieve these effects and result?
Thank you very much.
I answer myself, having found the solution.
Code:
 (defunc c:occhio (/ pins)
(setq pins nil)
(sing)
(= pins nil)
(princ "\nclicks the insertion point of the eye: ")
(setq pins (getpoint))
(command "_insert" "c:\\\autocadsupport\\\\blocchi\\camera.dwg" pins 1 1 breaks)
(princ "\nclick the point of direction : ")
grazie.
