nicolapastena
boys are doing a simulation, a rubber membrane inserted in an aluminum cylinder with pressure cycle that varies over time, the analysis I did is not linear dynamic, and I gave tt the constraints including non-conpenetrations between membrane and cylinder the problem is that the analysis seems infinite (even if hours pass), the progress indicator always indicates an abnormal 1.$% I attach the photo. if someone has advice thanks.
