edit 3d file from 2d
  • Thread starter Thread starter tecmec
tecmec
can you edit 3d file from 2 d?
I better explain to myself once I create my 3d file I pass it on the table, from here for example I want to insert a hole or take a dip... is it possible that it also automatically comes to the 3d file?
I think other softs can do it.
hi, sincerely I have never proceeded this way; I believe that you can change the "guidelines" that are already present. However, I think a good method is the "open reference model" command under files. You make the change, save the model again and regenerate the table.
alex
You can do it. from the properties of the table you can select the quotas to display, the share of a diameter for example is nothing but the value you give to the hole you realize on the model 3d (parametric). with a double click on the share you can assign a new value. to understand us better, it looks a bit like when you change the values to the quotas of a profile on the model:smile::smile:
Thanks was exactly what I was looking for, I remembered something but I wasn't sure.
Thanks again.
