edit design views
  • Thread starter Thread starter ance
ance
I would like to know if you can make manual modifications of a drawing view.
What changes would you like to make? to the views? ?
those are seen of the model, if you change the model you will see changes in its views at the table. we say that from the table (if made in a certain way) you can make "dimensional changes" to the model, but not add features.
then you can "scarabocchiare sopra" with sketch tools.
Mar
I mean just like that, i.e. once you get the views from the model, if you can switch to a kind of 2d type explosions of acad, otherwise if you can export the file to another format? I have no particular reason to use this passage, it's just a curiosity.
Hello and thank you
Hello and thank you
when needed you can test in dwg/dxf
I add that at this point close solidworks and continue with autocad or dwg editor.
Yes, but why? :smile:
I am forced to do so only if I have to send files to those who have only acad (but if it is only for pdf display).
or to consult them when they send to me plans of entire plants (or departments) that are then redesigned with the positioning of the new installation.. for that I have no alternative to 2d.
Mar
