edit dynamic block
  • Thread starter Thread starter piratabobo
piratabobo
hello to all
I'm trying to create an automation that will lighten my work, but I can't ride "rain from the hole", I use autocad 2008 I have several dynamic blocks to insert into my design, all these different blocks have in common "the length" so as I insert them I have to type the length, at this point I thought something in vba that allows me to insert these blocks in my design and in automatic form to change the "longness solved"
I make an example of what I would like to do:
I have several dynamic blocks that have rectangular shapes where the length is variable, I insert these blocks into my design, depending on the type of block, I have to vary the length, and this is exactly what I wanted to automate change of length as the block I can insert but I can not edit in vba form the dynamic attribute of the block.
this is the code I use to insert the block
Code:
dim obkref as acadblockreference
center(0) = 1: center(1) = 1: center(2) = 0
set obkref = thisdrawing.modelspace.insertblock(center, "blocco", 1, 1, 1, 0)
Thanks in advance to anyone who can help me, and I hope I've been quite clear in exposing my problem.
hello to all
Code:
attached an example dwg file, from macro launches and selects an insert point, will be inserted the dynamic std block of autocad of the hexagonal nut. Once inserted will appear a window with the list of allowed values, select the value and will be inserted the block with here values.. .
very similar to what you have to do.
if you need more detailed explanations please ask.
hi shape I tried to change the insertion of the dynamic block in this way:
Code:
'inserisce un blocco dinamico
p(0) = 1: p(1) = 1: p(2) = 0
set blocco = thisdrawing.modelspace.insertblock(p, "100-7", 1, 1, 1, 0)
variabile = blocco.getdynamicblockproperties
for i = lbound(variabile) to ubound(variabile)
    if variabile(i).propertyname = "lung" then
        variabile(i).value = lungh
    end if
    if variabile(i).propertyname = "larg1" then
        variabile(i).value = larg
    end if
next i
blocco.update
only that when I have to vary the length of the dynamic block, being this created with the ironing action is not stretched, I press that the stretching should be made to the left, while changing the action and pulling the block to the right works everything, but the problem is that I have the need to iron the block to the left.
is it possible to do this or do I have to iron right?
Code:
    end if
    end if
next i
blocco.update
I said so I didn't understand much.... is it not that you can assist the request with the block dwg and the code in toto, so I understand better the problem?
thanks to the same shape I solved, the problem was in the fact that I inserted the parameter from left to right and then I tried to iron the block to left, I reversed the verse of the "linear parameter" from right to left and now I can safely and iron the block.
Thanks again
