edit file template failed.
  • Thread starter Thread starter Trattopuntolinea
Trattopuntolinea
Hello.
I press that "use" inv.2010.
I apologize for the request for you banal:
with reference to the iproperties window, of an ipt file, I would like to change the item "precision required" from low (default) to very high.
I have tried to select very high and save the changes, but in the end everything returns to the default values.
I also tried to change the template, with the same result.
Could you please tell me where I'm wrong, or should I install some update?
thanks in advance for every suggestion.
Say hi.
tract pointline
