GabrielD
hi to all, use solidworks 2011 and for student licensing problems I do not have the possibility to install service pack without losing the routing features, with sp 0 in the routing library I only have pipes with gas measurements and I read that with the sp 3 are added all the measures iso.
being the first time I have to compare with routing and having to use pipes of diameter 11/16mm (int/ext) I do not know how to come to head, I tried to create flanges starting from those diameters, but once inserted in the axieme and started the routing requires me of routing files and I have no idea what they are.
Is there no way to change existing pipes with the diameters I need? taking into account the fact that I do not need flanges, fittings etc. if not for the beginning and end of the path.
I hope to have been clear and thank you for the attention!
