francesco1990
Good evening,
I apologize in advance if maybe the discussion I'm opening had already been raised, but the key words I used did not show me discussions about my specific need.
I have performed a joint gusci joint in 3d environment and of this I have to deliver the table with intermediate section of the component.
This includes screws at the section plan, so I had to specify to the program not to dissect the whole bolt in order to maintain the right construction of the head and the nut.
However, the threads of the screw must be marked in the table and the problem arises here. I have tried to add them from the annotations section, but what the program proposes does not follow the norms. also other details (thickness of some lines etc. ) I'm not what they should be.
I therefore ask myself: "How can I directly change these views on solid works? "
I remember that on solid edge there was the possibility to do this, but I did not find an equivalent on sw.
If a way to solve my problem is not there, how do I import everything on autocad without losing the scale of the views?
thanks in advance
france
thanks in advance
france
