editor styles in inventor 2022
  • Thread starter Thread starter Daniele91
Daniele91
Hi, I found a problem with the new version of inventor 2022 in my pc.
Specifically; opening the idw template (original version), going to management, editor styles and clicking on save, exits a message of migration of styles (message never seen before) to migrate old styles on the current release. If I click (then I migrate), I create a problem in the style library, in the sense that by opening the ipt templates, iam, ipn, I get mistaken about lighting styles and above all the option for choosing environments within lighting styles. I tried to uninstall the program 3 times from the pc and reinstall it thinking it was an installation problem but the problem still arises. for scrupulous I installed the program also on my pc where no previous version of inventor had ever been installed, but also in this case I get the migration error.
Can you help me if there is a solution?
Is this abnormal message coming out to you? Thank you.
hi, the migration I made then I opened the various templates and updated the styles to match the library, saved the templates, problems I did not find. But I did not have customized environments and lighting styles, maybe the error is restricted to that use, I don't know.
Thanks for the answer. browsing a bit in the form of autodesk I found a user with the same problem. Unfortunately it depends on a bug of the version of inventor 2022 that should fix with the next update. Thank you.
last year the first update comes out at the end of July if no mistake, if there are these problems we hope they will do it first.
actually looks like a "bacus."
some solved by replacing the lighting file in the date design folder.
I attach my to you from my backup of the first installation, but I do not assume responsibility for any problems.
