Paulì_zx
I have a problem for you. I have made a pair transmission joint, in which I use an elastic joint type sgf s34, is an elastic joint like that in figure.
what I was wondering was if someone knows how to estimate the duration in hours of the joint before they were destroyed. a company document itself reports:
"Sgf elastic discs do not need maintenance!
the duration of sgf elastic discs depends on torque, on the angle
deflection, radial and axial deformations, temperature, type
drive and environmental conditions.
the use of elastic discs under limit conditions reduces the duration!"
I would like to know a numerical estimate of that duration.
I ask you this because maybe you have already come across and know how to answer me.
Thank you in advance.
