exxon
the easiest thing is to understand the concept of "circuit". a circuit is a ring closed which includes one or more elements equipped with two terminals. only in a closed circuit, it circulates current.
if you take the battery from 400 v and with one hand touch a terminal, when with the other hand touch the other terminal, "close the circuit" (and stains flashed).
When you touched the first of the terminals, there was no circuit yet, there was no current and you could not notice anything. even if you had your feet in the water, because the second battery terminal was "flying", not connected to anything.
if one or more elements that are part of the circuit are insulating, the circuit is "open" and the current does not circulate. as an example we take the battery first, but we touch the two terminals with a rubber glove on one of the hands. Now, the circuit has also joined the piece of rubber between the hand and the pole of the battery. the rubber is insulating, the circuit is open, the current does not pass and you survive.
there are not only conductive materials (such as metals) or insulating materials (such as rubber). There are countless intermediate cases. the ground is one of these. If the soil is wet, a bit of current makes it pass, if it is dry just not. fresh water is a bad conductor, sea water instead is a good conductor.
if one or more elements of a circuit are these "intermediate" materials, the amount of current flowing (and consequently the effects it generates, including the possible lightning) are directly proportional to their goodness as conductors. the other factor is the voltage of the generator: if the generator is 400 v, in order to have concrete effects, All circuit elements must be good conductors. if instead I have a generator of 10000 v (like that in electrified fences), although one or more elements are bad conductors (but not insulating), as in the case of wet soil, then I will still have an obvious effect.
