electric schematic
  • Thread starter Thread starter gaz89
gaz89
Hello everyone!
Is it lawful to ask in this section an aid for an electrical scheme (just simple enough given there is only a fan and a residence) since I still need for the thesis project in mechanical ing? :
before describing everything I ask and in case it is not possible to gate the post.
Thank you very much
Hello everyone!
Thank you very much
if by help you mean some suggestions you are welcome:finger:
If you ask, and it doesn't seem like your case, pirate material, porn (you never know with the times you run), etc. then I guess not.
What are the questions? :tongue:
post everything and "before" that some person quite prepared can "illuminarti":smile:
perfect :) I waited for confirmation.
then,I have inside a dishwasher,a fan with rated voltage 24 v and power of 120 w.
then inside the same system I have a resistance to 230 v and 275 w.
of this system I should make an electrical schematic with these two components, also it is to add a switch and a timer.
Attached I put the sketch of the sketch.
