maca75
Hello everyone
I tried to do a research and I didn't find any arguments about it, I apologize I had to be wrong.
My problem is the following, for a university course I have to calculate a flat frame using the beam44 element with a released end, to model an internal hinge bond, and to compare with the calculation obtained by beam3 and application of the couple dofs.
everything goes well until I try to create the beam44 element table, setting tables to see the normal effort and cutting on the beam (mmomx and mmomy) I get nothing even if I know that the beams are subject to compression/traction and cutting; the table instead relative to the bending moment instead comes out without problems.
for the parameters to be assigned to mmomx and mmomy I used the beam44 table with the following parameters
mmomx smisc, 4 smisc, 10
mmomy smisc, 5 smisc, 11
I also did a test with only one bound and loaded rod axially but nothing and also when launch solve I always get a warning message but the same gives me the solution.
someone has some idea where it might be the catch, thanks to everyone for the interest
Michael
Michael
