elements patran celas with variable stiffness
  • Thread starter Thread starter flying
flying
Hello, everyone.
I have to insert in a paran pattern of the spring elements with variable stiffness.
The question is how can I change my stiffness? I have to insert a field field and change the stiffness within the field field is it possible to do in some other way? ?
all this is needed to simulate debonding on a bonding. the forces on the springs should grow until the rigidity of the spring is maintained different from zero (as a normal celas with constant stiffness).When stiffness assumes a near zero value, the forces on the springs should zero.
If anyone knows any other way to simulate such a situation, I'll be happy to receive suggestions
