elements without property
  • Thread starter Thread starter Nastran994
Nastran994
Hello, everyone! !
I have a problem with patran's analysis. practically I make a mesh on the surface (to make mesh more dense or less dense according to the area that interests me) with elements tet10 or tet9 with mesher "paver". When I analyze the whole model, it tells me that there are elements that have no property. when I set the property I did properties->solid and I selected the solid since nn makes me select the elements. I tried to give the property as 2d but tells me that the elements tet9 cannot be assigned. What am I wrong? ?
thanks to all in advance
I don't understand why you're talking about mesh on the surface, if meshi with solid tet10 meshi elements.
If so, and you have actually made a solid mesh, with tetrahedral elements, (viola), when you give the property you must first set elements (top right) instead of geometry. then select all the elements. if you give it to geometry you must be sure that the elements are associated with geometry.
Obviously you cannot give a 2d property to a 3d element and vice versa.
I would like to get thicker mesh in some areas and less dense in others, so I do 2d mesh, but then when I go to give the property to the piece I can't get it. and if I do property->3d->solid 1 then when I launch the analysis tells me that there are some elements without properties defined
probably it is already wrong to make the mesh 2d, but I would like to jam the mesh some areas of my solid, how could I do? ?
use the mesh seed on the edges of your solid and define the number of elements or the size of the element. then make solid mesh directly. always that patran sees the solid closed.
once made the mesh seed on the edges as I have to do to have the complete mesh on all the solid? ?
sometimes typing 3 words on google "patran mesh solid"
find an answer to your questions:
and if you have doubts, at least a little higher, then expose them here.
but asking a question for such a trivial matter is not constructive. .
I had already seen this video, but does not use the mesh seed command, and also does not make mesh more thick in some areas of the solid as I would like.
ok, of course, but your question, on how to make the mesh on the solid, is answer from this video, the question about how to fix the mesh, was answer above, precisely with the mesh seed that gives the possibility to control the number of elements on the chosen edge.
I probably explained badly, my question was how I could give the property to the solid by making mesh on the surface. but I realized later that it was a stupid question! I made mesh on the surface because it was the only way I could put mesh on, but with mesh seed I solved
Actually there is a way to proceed to a surface mesh, then make a solid mesh. but it is much more complicated. so, I would avoid discussing it if not necessary.
serves when the solid is not closed, and the solid meshator fails
no for now is not my case. Now my problem would be to define the material to do a non-linear analysis for a plastic deformation without having at your disposal the sigma-epsilon curve, in case I can not see if there have already been open topic on this or I create it.
