fabiosam
hello to all
I am trying to define a correct methodological approach to the management of particularly complex axioms.
it is not easy to explain the question: I created a simplified project, it is not a real object but I think it is very close to so many real situations.
The project is this:
is composed of a tray where a pin rests, the pin is hollow.
there is immediately the problem that we have to eliminate the part of the tank that intersects the pin. in this case the part to be eliminated has a perfectly cylindrical shape but I think about + complex cases where this does not necessarily occur.
After drawing the box and the pin (but without creating the cavity) I create a side file from where I derive the two objects and exploiting the combined command (with output size) I can cut the surplus. except this .ipt with box #2 name.
the pin could not be immediately hollow since if it had been I would have obtained as result this
At this point I have to create the cavity in the pin but I can't do it directly in the file and I see myself forced to create another file (called pin #2) where the file comes and I empty it.
to the file I create the axieme using the two files box #2 and pin #2.
But isn't there a way to do everything directly inside the axieme? I noticed that the combined command is not present in the environment together.
Thank you for your ideas, opinions, suggestions
is composed of a tray where a pin rests, the pin is hollow.there is immediately the problem that we have to eliminate the part of the tank that intersects the pin. in this case the part to be eliminated has a perfectly cylindrical shape but I think about + complex cases where this does not necessarily occur.
At this point I have to create the cavity in the pin but I can't do it directly in the file and I see myself forced to create another file (called pin #2) where the file comes and I empty it.to the file I create the axieme using the two files box #2 and pin #2.
