eliminate fold lines from a single sheet multi-body
  • Thread starter Thread starter Onyx68
Onyx68
I exposed the problem of the visibility of the fold lines in a multi leotard of only plates. I know ok not and the Orthodox way to exploit sw but not my choice. from the technical assistance sw I was not solved the annoyance of having visible every fold line in the finished product. the answer of the technician was to click on each sketch and hide it with the command hide or turn off. rejected resolution as from the image I attach I have about 30 details and more to each regenerate and save these lines appear the same. the other solution and keep the sketches hidden from the command. This solution also does not confuse with methods of designing large plants where changes happen continuously until you define the project with light-spegni the sketch that I need at that moment and not all. often use sketches of a particular to place another. such as the example of flexible pipes, sketch repetitions etc.
I complained about the software only at the service center with here the company treats but not to the mother house.
do you mean that the sketches of the fold lines are also displayed when the sheet is not lying? this also happens to me, but very rarely. I don't think it's a version problem (that I ask you to enter the profile) because I've been using 2019 for a 3 years and it only happens recently.
as you see from this discussion is an old problem https://forum.solidworks.com/thread/200112. I didn't find any more arguments about this.
Does it happen to you in the assemblies?
the solution proposed in the linked discussion is what seems more practical to me (it does not solve the problem obviously); to speed the selection of fold lines, in part environment, write in the filter box above the feature manager bending lines so that you see only these in the tree, at this point select all and suspend it is a moment
si
It happens that the same annoying lines remain visible also in the assy. the version of sw and 2020 sp.3
in a multiboby consisting of a minimum of 30 details almost all in sheet ... then it does not solve as I explained why to every save and regenerate it comes back from head.. .
in a multiboby consisting of minimum 30 details almost all in sheet metal
in fact does not solve the problem, but speeds up the method of rat
then it does not solve how I explained why every saver and regenerates comes back from head.. .
this is wrong because if you suspend the sketches, which will react only in the flattened configuration, they will no longer be visible.
as I have written and as you can see from the linked discussion is not a specific problem of the version. I kindly asked you to put it in the profile because, as you know, knowing the version allows you to circumscribe the answers and possibly exchange files appropriately.
hi, is it possible to have the file of assembly and parts of this project or another one presenting the anomaly to do some tests? Thank you.
