eliminate part together
  • Thread starter Thread starter sofa80
sofa80
Good morning, I have the following problem
in a file of assembly I entered another set from which I first copied and then deleted a part,
the problem is that the part in question always appears to me in the main folder of the file , and in the distinct materials,
if I try to delete in the file folder when I open the set it gives me error because the part is no longer inserted in the set as a component
I hope I've been clear thanks
Obviously, the part must be eliminated from the axieme and not from the folder.
n a file of assembly I entered another together from which I first copied and then deleted a part,
and where did you copy this part?
summing up:
is the part to be eliminated in the main axieme?
is the part to be eliminated in the subaxieme?
to know if and where a part is located do:
for first thing file menu > references
second what write the file name in the search box above the feature manager
if I get out of the set in the folder I always stay and always appear in the separate
the part to be eliminated does not appear in the main set because inserted and then deleted
is located in the subassieme
allego image highlighted the part in question
Then you didn't understand your problem.
deleting a part from the axieme does not mean deleting it from the windows folder ( fortunately)
in the separate materials may or may not appear, depends on how you set it.
I'm sorry I didn't explain myself.
so if I want to delete a part in the windows folder because in the 'assieme I already deleted (it is only present in the subassieme) how do I do not have problems? ?
how to do not appear separately? ?
If the part is present somewhere in solidworks models (axiemi*, part references, drawings...) you can't delete it from the windows folder.
*a set is always such that it is inserted into another set or not.
the question is: why do you want to delete the file from the windows folder?
depends on the final result and how it is managed:
you can set it as excluded from the distinct materials, but then you won't even see it in the subassieme's distinctness.
you can set the first level distinction, but then you won't even see the other parts of the subassieme
you can make two configurations in the subaxieme, one in which the part is included in the separate and will be used for the design of the subaxieme and one in which it is excluded for assembly and will be used in the main axieme
Okay.
I want to delete the file from the windows folder to have the situation clearer and neat
Thanks again
