eliminate sheet explaining from styles
  • Thread starter Thread starter Catafratto
Catafratto
in the past I have made myself an explanation rule for every thickness: today I wanted to give a reorganization to the matter, rename some styles, try to shorten them etc. etc. but now I find myself with a lot of sheet metal explaining rules in the global library and I can't delete those that I don't care anymore (in fact I didn't realize that the rhino does not rename a patch but duplicate with new name:mad:)
:rolleyes tips:? or I messed up well:redface:?
as a solution I created a new custom style library: However, I think it is impossible that an unused style cannot be eliminated. . .
I finally found the solution, which is very simple once discovered: with the program "management library of styles" it is possible to do as I asked in a simple way, maybe after making a backup copy. I used it only for migrating libraries to the rel. later and I hadn't thought about it.
