eliminate the link between two products
  • Thread starter Thread starter theredman
theredman
Hello everyone, I created the product of the side seats of a plane, then using the "Send" function I created a copy of this product (and its parts) in a new folder so that I can use it as a base for the central seats. . .centrali.webplaterali.webpHowever, when I try to open them together within the same session, the second product takes the same configuration as the first one I opened.doppia.webpMoreover the small icons next to the "part2(2.1)" are different, in the first there is a kind of thunder, in the second the symbol of the link, I think the problem is there, you know how can I solve it?
Hello everyone, I created the product of the side seats of a plane, then using the "Send" function I created a copy of this product (and its parts) in a new folder so that I can use it as a base for the central seats. . .View attachment 35415View attachment 35416However, when I try to open them together within the same session, the second product takes the same configuration as the first one I opened.View attachment 35417Moreover the small icons next to the "part2(2.1)" are different, in the first there is a kind of thunder, in the second the symbol of the link, I think the problem is there, you know how can I solve it?
you don't have to use the function "send to" but you have to use "new to" and replicate the parts that will be changed, the rule that you should always keep is "a part, a model".
the presence of the red lightning indicates that the part is a replica of an element defined in a feeding set from where you are using it.
