eliminate triangles from topographic surface
  • Thread starter Thread starter realmicrobo
realmicrobo
Hello everyone, I've been jumping quality 2d/3d for a few days. I am using revit 2012 and I find it difficult to insert a topographic surface we say inside a polygonal, with quotas in the known vertices, from me defined...to be clear the automatic triangulation of revit prevents me to define exactly the contour of the topographic superfiie. . .
Maybe I'm wrong or even command! ! !
Basically I shaped a small building and outside the entrance there is a courtyard with irregular shape perimeter beds. . I have done them as a grass-finished sole and all the courtyard as a topographic surface, but I go to invade even the flower beds....it really invades me also the building...to avoid that I make sup. topographic sum of many rectangles. . but it's normal all this... too laborious. I'm definitely wrong. .
the need for all this is to show in the sections the soil....
Thank you.. I hope you explained the problem well.... hello
the automatic triangulation of revit prevents me to define exactly the contour of the topographic superphylas. . .
It's not wrong. but you can divide the surface and erase what is not needed
