elimination st3 da win10
  • Thread starter Thread starter cacciatorino
cacciatorino
I have a pc on which they were installed st3 and win7. In the past I upgraded to win10 but now I need to use st10 on that pc. the problem is that the windows installer does not make me delete st3 for compatibility problems' with the uac (which I disabled).
Then I proceeded to delete the st3 folder and all the registry keys I found, but going to install st10 won't let me do it because it still finds an old solid edge in the pc.
I also downloaded revo uninstaller but having already deleted everything does not let me uninstall it. I also tried to reinstall st3 so I could take it off with revo, but it doesn't let it install, he too, because he finds a man already present.
Do you have suggestions?
For now I try to install st10 in multiversion, let's see if it works... .
Maybe some alternatives to unisteller revo might work, for example:
  1. Uninstaller: iobit uninstaller is a free program that offers an advanced uninstall mode that searches and removes residual files and registry entries after uninstalling a program.
  2. geek uninstaller: geek uninstaller is a lightweight and free application that helps you uninstall programs and remove registry entries and residual files accurately.
  3. wise program uninstaller: wise program uninstaller offers an option to uninstall programs and remove all the associated files and registry entries. is simple to use and has a forced mode to remove stubborn programs.
  4. bulk crap uninstaller (bcuninstaller): bcuninstaller is an open-source program that allows you to uninstall multiple programs simultaneously, also offering advanced features for removing remains.
  5. zsoft uninstaller: zsoft uninstaller is another free tool to uninstall programs and clean program tracks from your system.
  6. ashampoo uninstaller free: This is another free tool that offers advanced uninstall features, including search and removal of residues.
Thank you, I finally solved as described here:
