elimination system representation coordinates u,v,w in annotation
  • Thread starter Thread starter ferro.84
ferro.84
Good morning.
I ask you if the parameter that governs the representation of the coordinate system of the parts is set definitely. su Ignore.
I attach image.
In fact, you have to re-set this parameter at each start of the cad, as it is default on calculated.
grazie :)
Good morning.
I attach image.
grazie :)
modeling is born to save the settings with all the related changes to each closure of the software, however, it may be that the softwarehouse (in my case the cdm) impose the styles and other centralized modeling and annotation settings so that at each start always loads the same, to avoid that you have to go in annotation-tools am- management
click in the small dart and remove the pins of the alignment at the start.
In this way it should always charge you the settings you had at the closure of the software, but be careful that if the software house technicians see this they can twist the nose, since they preach the opposite.Allinea Stili. 2JPG.webp
