Idlanir91
Hello everyone, I should realize the three-dimensional model of the elephant house of norman foster a copenaghen on revit (premit I use the 2013 version). the first problem that has been proposed is the realization of the two domes with an elliptical profile, in fact even regular as given by the section of two slightly tilted toroid surfaces.
Since they're the first weapons with revit, do you have any idea how to make such a cover? I have for now imported the dwg of the cover plant on revit and tried to model it through the local mass command and then with the revolve command but with little results since I can only get the volume of an ellipse failing to deform it and adapt it to the silhouette.
I should finish the whole model by this week so I don't have much time available, so I need as soon as possible a help.
I attach you in any case the images of the project so as to have an idea!
