emergency aid alias automotive/studio tools
  • Thread starter Thread starter carla84
carla84
I have a problemone with alias, I hope you can help me.
I don't know well why the program decided not to run, when it seems to him, side view windows (right and left). I'll explain. I start working on the imported dwg file in alias, it's okay until it decides that the windows need to have the zoom connected (and this problem I can fix it, in practice it activates the parameter windows sync) and at the same time decides not to display anything in the right window (even if I open it and close it or if I open the left I don't see anything)....
Can someone help me?? ? Just two days from a parter, I had to play the joke. .
same thing last year with tolerance. . every now and then I moved the values, at his will --" mah!
Anyway thank you so much and good year to all!
Hi, I'm not using alias, but I'm a student.
if the problem is serious and the partial is in a few days use the "classic" way of the student to the sgoccioli:finger:
uninstall everything, clean your registry with ccleaner and install everything again.
bye:
Usually when alias does these bizzes, it means something happened to the drivers of the video card. Maybe you just updated them.
bye:
It's what I would do if the program was installed for at least a month, but I just put it... and cmq last year had not served anything... I hate it.-"
In the meantime, I expect the solution to me from the sky to move forward with the tables, but what a package of program... Sgruent
solved!
for scruple, in case it happened to someone in the future I explain how:
according to the window where you no longer see anything going in windows -> object lister and click on the colored squares that are now colored only for half
Then if you ask me why I can't explain it to you... today I turned on the pc, I started working well and after 5 minutes I presented the problem... then missing objects and windows sync activated... booooh!
