emulsified
Nicolò040297
Good afternoon to all,
I would be interested in creating a template file (to understand how standards exist in inventor x sheets and parts) for profiles.
the purpose would be to avoid the passage of creation of a set and insert the profiles from the center contained, and to create the profile directly but obviously also using here in the center contained.
I hope I explained.
First, you're in a wrong section and not in inventor's.
second, the fact of having different parts/lamiere templates is due to the fact that the 2 things enable different modeling commands.
third, I don't know what you want to do.
that arrogance,
In the meantime, you can answer the good afternoon.
In addition if you have not understood the question explain to me how you can deduct paragraph 1 and 2.
However, I was asking for access to the creation of a profile through the contained center without having to pass through the creation of a set.
point one, if you do not write in the right section of the forum the post will have little visibility from inventor users.
point 2 is you talking about hardened (sheet parts)
point 3 if you explained better pima you avoided losing time both.
Good day
if the idea is to have an ipt file that is created as a derivative of the contained center, that I know, at least until 2020 that I use now, does not exist. needs the starting aid where to insert it.
