ector
do you know how to draw a wheel with an endless screw that gear? I can't find anything on the web...
Hi.do you know how to draw a wheel with an endless screw that gear? I can't find anything on the web...
What do you mean? ? ?do you know how to draw a wheel with an endless screw that gear? I can't find anything on the web...
I see you use swx.do you know how to draw a wheel with an endless screw that gear? I can't find anything on the web...
depends on the transmission ratio. on the catalogs is specified if the pair you're choosing is reversible or not.a question maybe idiot, with screw system to crown the system is retrograde? i.e. if I turn the crown the screw turns?in my opinion I think no... or better I found nothing to say it... .
then you have to deal with the angle of the propeller, friction coefficient and tilted plane.If I build it?
You've already written a hunter:"depends on the transmission report"then summarized we can say that :bekle::bekle: : depends on the transmission ratio.If I build it?
I agree, this is a producer of luxury stuff.If I were you, I'd take something already done.
if you have no experience of vts risks that at the first blow this does not work.
endless screw transmission is always irreversible. 'retrograde' is not an adjective that applies to broadcasts.depends on the transmission ratio. on the catalogs is specified if the pair you're choosing is reversible or not.
In theory it is as you say, but I remember last year we had mounted a mvf bonfiglioli with rapp. 1:7 and it was very reversible, in fact during the tuning we could move forward and back the cart that was moved by a belt that took the bike from the slow shaft of the reducer. It's not like it should work that way, it was just a secondary effect.endless screw transmission is always irreversible. 'retrograde' is not an adjective that applies to broadcasts.
No no, we could have him do even ten laps back and forth pushing him from the slow tree instead of the fast one. . .I feel new... but I could be wrong, it's not my field.
Are you sure this isn't just about game? often the gearboxes at vsf always work in grip and therefore does not look after the preload. . .
Yes, I do.depends on the transmission ratio. on the catalogs is specified if the pair you're choosing is reversible or not.
in theory:biggrin:endless screw transmission is always irreversible. .
