ector
the problem in my case would not exist because the relationship of red must be at least 100....
cmq interesting the topic, I have to deepen for benign. . .
I think you are perfectly right, in fact if you give an eye to the pages of the catalog bonfiglioli that I attached to the message #20, there are transmission reports for which v.s.f. are totally irreversible. Those two pages are very interesting, especially when they distinguish between static and dynamic irreversibility.However there will be a greater angle of the propeller than zero that will give irreversibility. In fact if I have a thrust force of the tooth on the propeller, I will always have a circumferential component (which turns the propeller) and an axial that (in addition to risking splitting everything) generates friction that brakes rotation.
It also happened to me when I discarded, or for two years I run downhill and goes that it is a fairy tale, courage.:biggrin:My memory, after my last birthday, was a little cloudy, but I was a kid, man! !
:smile:
