engineering reference non gira sulla 20x64
  • Thread starter Thread starter gerod
You can keep it for you.
I'm not a joke at all.
I thought you were seriously comparing the two packages and a constructive discussion could arise. it leaves me puzzled your comparing a modeler from you defined contextual with st. obviously you do not know it so well.
and with this I do not want to defend either.
simply judgments by party taken bother me.
Let's be good!
I just wanted to report the defect because I found out, alas, by mistake.
this is also a signal for other users, in the sense that they know that some things do not turn on x64 (v20).
That's all.
then a cad is better than the other... are opinions, ideas, subjective opinions.
I feel good about it for years. certain that some choices are questionable but I believe that also from the other parts there will be little pleasant situations for users.
you make choices, sometimes correct, sometimes less correct, sometimes need to be cut back.
I therefore ask you to keep the discussion within the limits of the title.
