engraved with text a plate
  • Thread starter Thread starter ALIENEBE
ALIENEBE
Good morning to all,
the question could be simple for the "lights", but I learned and I am learning step by step, I am standing at a wall.
in creating a trophy for a forum of which I am moderator, I met some inconveniences, or if we want, inconveniences due to my gaps or inexperience:
by making a cup, on the base I would like to place a plate with descriptions, engraved or printed, in short, put something, but I wonder, I have to create the letters and then print them or engraved them or there is a tool that allows me to write and then work as if it were engraving or printing?
then from the base "wood" I started with the first base with the rotation stucco, getting the pedestal of the cup, but if you want to work it, for example to make it to spikes or however to affect it on the surface, how can I proceed?
thanks to all the designers, who will lose time for me and for something so simple....sorry anyway.
antonio
antonio
as for the writing to be engraved or printed just enter the text on the active floor on the face where you want to do the processing (menu contour and command text geometry and choose font type ) if it is a text that is not among the default fonts usually drawing with me10 and then the amount on annotation and the copio/neck on the plane if the font is not there among the available I look for it on the web and insert it into the true type folder. add or remove material and depending on the shapes you want, to affect it on the curved surface we go on the complicated, in the sense that you have to wrap the text. I don't remember.
look attached image.
I didn't understand what you have to do, try to look at if the "southdivision" command is your case.
thank you seriously, letters solved, and excuse me for ignorance, but congratulations, 2 effective and resolute words.
I mean this:
work it somehow, not to leave it smooth
I mean, for example, above the white base, I realize the cup, I can write or engraved on that surface, or realize it as if they were the ears of a balloon... and then apply the handles. .
at the end a cup...
ps should be supported the head of a feral hog, but it would be complex, and I limit myself to the cup
at the end a cup...
I honestly haven't figured out what you have to do yet, do you have an image of something like what you'd like to get?
Hi, I'd like to do this, but I don't know if me10 can.anyway I would like to realize the waves we see in the cups that place, in short, perform some workmanship, and then apply the handles, working them.
another aesthetically pleasing idea would be to rest on 4 columns, but (I don't know the term) twisted, like the columns of san pietro in Vatican.Thank you.
I'm afraid you'll have to work with the surfaces... but then what a mold has to do or what
Hello, thank you for the answers.
In fact the 3d eelk does not realize it, but I will try to work the cups to make it aesthetically pleasing.
no, no, no mold, I design molds for step-mounted funnels, from tape I realize a product, a threaded nut in a 14 mm high m10 stroke, with 2mm tape.
This is a prize that I must give to the 3 winners of a contest organized by me, and in addition to matching virtual money, at the 1st-2° and 3rd is awarded a trophy.
But I think I got into a job a little longer than I expected.
Bye!
antonio
Bye!
antonio
The type of model you have to do is beyond the possibility of osd and even normal mechanical cads.
I think that to model what I see in the photos the best product (best in relation to the price) is rhino, possibly you can then import the models in osd to complete everything with solids from mechanical processing.
I mean this:
allegal images with the special command: "Go to advanced mode" under the "fast response" window and then on the "allegati" icon, the one with the "graffetta" symbol.
Thank you for your availability, I had actually thought of a 3dmax or similar software.
Anyway I tried sculptris, but I abandoned him because I looked like a kindergarten baby!
I will try its indicated solution, but currently, (see that deliveries are scheduled for next Saturday) I will limit myself to the most elaborate realization possible, software allowing.
I thank you again for kindly responding to a user with few messages (writes when he needs), and for accepting also simple questions, seen from your career.
I wish everyone a good job.
antonio
antonio
"la" to whom? ahah
Come on, we're like the ones in the bathroom, all the same!
:eek:
antonio
You could start from a model already made since the deadline is so close, then the model adds what you can do.
on grabcad.com you can find models of cups similar to those you want to make , in order to download the model you have to enroll and
then courtesy wants ....give a "like" to the author of the work (which is not me).
cup model:http://grabcad.com/library/fa-cup
