envelope eliminata
  • Thread starter Thread starter Lawrence
Lawrence
Good morning, everyone.
I have to edit a file created by another colleague of mine in the past.
in this assembly there was an evelope, stored on wnc by echo, and therefore released.
meanwhile some good time has decided to go behind my colleague and delete the evelope inside the asm file.
Is there a way to re-enter the existing file, indicating it as a default envelpo?
thanks in advance
Good morning.
during the creation of a simprep envelope asks you the file from which to start and I think you can tell him to use the existing one. or you can create a new one with the same name as the existing one (which will not be in the ws) and then once you create the overwrite with the one you have in the cs.
Good morning.
Good morning.
when I try to create a new simprep initially asks me a basic name. only successfully asks me what file to leave. In that case, however, asks me a basic template from which to take the settings.
as to create a file with the same name, but it is not present in the ws, I have already tried: the problem is that the code in question had already been released on wnc, so it already sees it in the system and does not allow me to erase it.
