environment simulation
  • Thread starter Thread starter enz-OH!
enz-OH!
Good evening to all,
I have a problem with solidworks 2014.
I made 1 set consisting of 2 tubes and 1 plate.
the plate has the shape of the Greek capital omega letter, it has 2 holes at the ends (on the cylindrical surface that "beams" on the tubes), in which 2 screws with relative nuts pass to connect it to the above tubes.
as from title I would like to perform a static analysis in the simulation environment on the above axieme but when I go to choose the "bullone" connector does not place it on the hole because the edge (of the hole) is not circular being made on a cylindrical surface.
I'd like to know if there was a way to place it.
I hope I explained.
Thank you in advance.
win
Good day to all,
Mechanicalmg I attach the required model.
Greetings.
win
Hi you tried to insert a point.... otherwise you have to create a hole by force create an extruded cut in the hole and from a depth such that you create a complete tear hello... .
