abro
Good morning, I'm in a joint environment, I'm trying to draw a skizzo in the active part by copying a plan on the other side, don't you give me the chance to activate?
I'm sorry but I didn't understand what problem you're describing.Thank you, but why don't you update me a set when I change a part? It makes me crazy I'm planning!
Besides every time I make a change in the skizzo I have to remake the function because it does not update it.
you have inserted the two tubes as adjustable but then you have not inserted the values of length and thickness (baptized variables for the adjustable part); by inserting these values the parts and the assemblies are regularly updated.I have two tubes together, I change the length in the environment together, as I said it does not update me together or draft, madness
thank you always kind,you have inserted the two tubes as adjustable but then you have not inserted the values of length and thickness (baptized variables for the adjustable part); by inserting these values the parts and the assemblies are regularly updated.
if you do not need to adjust insert them normally and the changes of the measurements will be immediate by editing the parts.
I suggest you follow some tutorials on these topics
