environment variables (simplify body)
  • Thread starter Thread starter bikertia
bikertia
Good morning to all,
I use nx 7.5 and I would need the "simplify body" function. It should be a hidden function to what I understand, which must be activated by defining an environment variable. in fact when I look for it with the finder command tells me to set "ugii_dmx_nx502=1".
So? What does that mean? What do I do to activate it?
thanks in advance
then you should go, from explore resources on computer - management - advanced system settings - environment variables, and on those for the system set the variable (win 7).
then:
ugii_dmx_nx502 (regis above)
1 (regave below)
reboot ug and pc, then, always with the command finder you look for the simplify and run it... .
You mean that, right?
That's great. !
I solved so thank you!
I also found information about the ugii_env.dat file but I didn't understand much so I thought it was much more complicated.
Thanks again
I would avoid unnecessarily filling of new environment variables the profile of windows.
as this variable only serves nx I would do so:
-Go to the installation directory of nx 7.5
- enter the Ugii subdirectory
-In the middle of that disaster of files you have to open with a text editor (block notes for example) the ugii_env.dat file.
-At the end of the file add this line:
-Save, close and restart nx.
note: do not change the file ugii_env_ug.dat (which is what contains the general settings nx) but only ugii_env.dat.
depends on the needs.
keep the most in order is correct, but varies according to the needs:
if I don't remember bad ug follows this priority scale:
User system variables (valid only for the user you lodge with)
variable system
_
if it is more practical for you to centralize everything in the .dat file I recommend you to follow the procedure indicated by stefano.
my advice is to learn new commands, as they are the only ones that will be improved.
there is also macro speech and other programming methods.
once a command is relegated as 'obsolete' but not yet removed, then 'hidden', you will never have support.
if the new command does not suit you, make an improvement request (er).
nx is a constantly evolving software product to stay competitive.
However the command 'simplify body' has been replaced by the 'delete face' of the st.
I don't know what I use you should do with that obsolete command, but if you need to do a fem analysis, there are other dedicated tools.
No, I'd need to see some ducts as full. In fact, I still can't make him do what I want, only in cases of simple pieces. .
absolutely aligned to usernx: do not use these functions that are out of maintenance, activated with environment variables.
the place of the simplify was taken from the delete face.
I can only share nx and the_matrix user responses better avoid using out-of-maintenance commands, better evolve and upgrade to new commands.
so you will see that the result does not change, it is only a matter of habit.
synchronous modeling has had several implementations in the latest versions and I think it will still have many in the versions that will come.
Good job! !
hello to everyone, today I found that to start nx8 you must write(as command line) ugraf.exe -nx
I found out because I always used a batch file to recall templates, variable for space maouse, etc. and as executable I started ugraf.exe without adding anything else. with nx8 I noticed that it didn't work properly, license that jumped me, partiva power drafting instead of nx etc... and so I discovered this change.
Be careful if you use other ways to start nx8.
Hello everyone
Unfortunately the delete face does not allow to do what I need (see the ducts as full and full as empty), or simply I have not yet discovered how it is done.
the simple body instead let me do it, even if it is very laborious. .
the delete face allows to get exactly the same result of the simplify.. .
Unfortunately you can't use it.. .
