equation with hanging part
  • Thread starter Thread starter Gach74
Gach74
hello to all and early thanks for those who want to answer.
I have this problem.
I create a set of roll+wires, then I turn it back to a variable diameter vault (in the order of +/- 0.5 mm) and above it I go to apply a part in the axieme, therefore not saved, consisting of a ring as long as the roller table that has as the inner diameter the diemter of the previous turning.
the only way to tie the two odds is the equation and also works well until I go to subside the part in the axieme (which I can have and not have).
Unfortunately being a model 0 that will serve for hundreds of cases and having to deal with lazy users who do not go beyond the tip of the nose I need to make it ready to any eventuality.
I wondered if it wasn't possible with a if or other set a value type 0.001 (better 0) when the component is suspended.
I was reading and sincerely you did not understand what you mean, but only intuition. suspending a part means that that part is as if it did not exist, so if any object or equation that points to that part when it is spsesa go wrong. I think you should suspend the equation.
that sisgnifies unsaved part?
'the only way to tie the two odds is the equation and also works well until I go to subside the part in the axieme (which I can have and not have).
It is not true because the equation is linked to the part. therefore modifying this also updates the equation that the command is suspended or even deleted; it is mandatory instead that it is open to be able to communicate the variation.
