equipment for working center
  • Thread starter Thread starter Matteo_MB
Matteo_MB
Good afternoon
as I am bazzicando the workshop of my company (it should be obligatory for those who draw to realize how the finished pieces are realized and find a correspondence between what you studied and the visual experience!!!)
we come to the therefore.. .
I was asked to make an equipment that facilitates the machine positioning of raw pieces (various sizes). How do you advise me to proceed? modular equipment that can take a range of raw pieces or custom brackets? Thank you in advance!
Good afternoon
What kind of pieces?
What kind of machine tools?
Exactly, any more info to understand?
the modular thing is always a good choice even if it costs more!
the working center is a doosan 1250 and the pieces to be realized are steel parallelepipeds.
I think it's the only solution. . after various studies and research on the net.. circumstances suggest that I can't ignore modular bites!
modular morse.
Hello Matteo
Hello mecc.... .
even if it's too generic
establish a type of tool on a generic parallelepipedo
Modular clamps grinding a lot of money
width 150
300 useful
520 max width
coast around 1000 eurozozzi
equip a machine plan of 1000 :mad::mad:
many times to avoid such spending
low-use lathe spindles are also used
then everything depends on the tolerances
Thank you very much
hi shiren,
Could you be more precise, please?
how to use the spindles of the lathes?
Thanks, good work and good day.
some cut and perforated block (magari rectified also in the house) and 4 destaco from 50 euros. I would say that with little can be done so.
destaco are the lever systems (clamping system) of fixing that company precisely. are durable, versatile and very robust if well sized. and above all absorb vibrations very well.
hi shiren,
Hello Matteo
the self-centering spindles of traditional lathes lend themselves to be placed
on cnc plans
via staff
if you find those with four clamps (right and reverse) you have a great centering
and a good paralellism of the stirring
block your parallelepipeds as if you block them at the lathe
with the difference that instead of stringing the clamps so "horizontal" block them in a "vertical" way
in case of higher dimensions
can use the spindles with independent clamps
pero have very high tolerances
and you need a more specialized hand of work
you need to create "or" points where you can dispose of the pieces
via more or less stable tastators
as already mentioned in previous posts
there would be the need for a sketch or a tolerated design to understand
the type of equipment to build for a precise and possible cheap way
for a correct clamping of the piece
Thank you very much
hello mechanics
the tool of the photo
I should like to ask the Commissioner whether he is a member of the Commission.
on working centres
there are some types much more robbed with the same characteristics in steel casting which give greater guarantees of locking
even if the costs are huge
It's just my personal conviction.
the clamping of the pieces on the machine floor
can only be done with a quarry
threaded bar
console bar
Washer
and given
alternative
modular clamps or turning spindles
in commercial catalogues are alternative locking systems of all types
I assure you that you need little or at least you can block dimensionally insignificant elements
Thank you very much
