gaz89
Hello everyone!! !
a question about equivalent tensions.
then in an exercise with an attached image, once I calculate the various forces and moments agents on the tree I am asked to:
"calculate the equivalent tension of von mises at the most stressed point of the tree"
now the most solicited point is in b.
to calculate eq voltage for vm should use formula
but the problem is that I don't have the diameter of the tree in the data, how do I find it? Is it okay with the "maximum cut"?
Thank you very much and I apologize for the confusion
